They took our jorbs.
99S10Truckin said:
is there anyway to turn a 2wd into a 4x4?
yea, but after buying all the parts you could have traded your truck and bought a truck with 4wd on it
And I once asked, is there a way to turn a 4wd into a 2wd? If you get some solid info i'd be willing to trade you part for part. But isn't there something involving cutting off the front of the frame?
i did, its a major pain in the ass, didnt use a single 4wd s-10 part, except the tranny.
here's the basic rundown of how i did it, there are a million way and mine was probably towards the easier side:
-unbolt every front suspension pice
-torch off lower control arm mounts, half of coil buckets, and that little skid plate for the stock steering
-plate over large hole in frame where the coil buckets were
-fabricate leaf spring cross member and weld to front of frame
-fabricate shackle hangers and weld to frame
-bolt on leaf springs
-bolt on axle (see axle footnote)
-bolt on Cherokee pitman arm
-fabricate drag link
-assemble custom brake lines (mine are custom, but there may be a factory app for them)
-install transfer case (another footnote)
-order custom front and rear drivelines
so that was the easy stuff...
AXLE - i used a Wagoneer Dana 44 the first time around, it is strong enough for me, and the right width, but low pinion, i couldnt get a driveshaft to fit, largely because i'm running a very short transfer case. so i narrowed a f150 high pinion D44 to the wagoneer width, and swapped that in. the easier way to do it would be a jeep cherokee high pinion dana 30, but my last truck was a cherokee and got sick of changing broken front axleshafts. no matter which axle you choose you will need to fabricate new mounts on it.
TRANSFER CASE- i'm running a flipped twin sticked dana 300 went like this:
-pull t5 from my 95 s10
-pull t5 from a donor 4x4 83 s10 blazer
-dissasemble both trannys
-assemble front half of 95 tranny with rear half of 83 tranny
-have shop at school CNC an adapter to go from the 5 bolt patern on the t5 to the 6 bolt tranny on the D300
-fabricate new shift mechinism for D300 because it is now upside down
-install 27 spline input shaft in D300, and the LoMax 4:1 kit just for fun
-bolt it all up
running the NP207 out of the 83 would have been much easier, but not nearly as strong and i couldnt get a 4:1 kit for it
if this doesnt sound like fun, or you werent expecting this much work, sell your truck and buy a 4x4
sorry for the huge pic, but i'm stuck at the g/f's house, and this is the best on on her computer
Super Moderator
great info for suspenion how to, if have any more information, process, pics more easier for other members, send em to suspension FD/Mods
