Okay check it................
You have an all electric setup, (valves, switcehs, compressors, etc)... But you also have a bottle for higher PSI tasks such as hopping, quick ups, and hot compressors.
Is it possible to run off the bottle and when the valves dup out the Bottle gas, to reroute, and compress the used gas for later use?
Say have the exaust setup run to the intake on a compressor and into a 5-6 galon tank? This tank would have a Check valve/Ball valve, or electric so that you could reuse over and over the "recompressed" bottle gasses, or switch to fresh , "high pressure bottle gas".
Does this sound feasible? Is it possible? would it be worth it?
I'm thinking tat if you hada quality enough compressor, dryers, oilers, and what not that it would work. But would it be worth it? I'm gonna draw it up on a piece of paper real quick (at work right now, and can't do it on the comp).
If you guys have any imput pleas feel free to contribute....:thumbup:
Thanks,
Dawgnutz.......................................:idea:
Thanks,
