Cool build man, sad to see that 92 get cannibalized but the chassis seems perfect for this. Those ZR2 front end components should help with all the extra weight and you'll be able to slam that *.
I had a dream of going through that 1992 s10 and painting it, and new interior etc. but the trifecta of my pocketbook, dream and elbow grease were all out of proportion.
It's pretty rust free, but every single panel has some kind of damage; My friend who owned it before got it for a cheap hunting truck, The driver side was wiped out we just replaced the door so the glass would roll down, but still has a crushed rocker and banged up behind the door, the tires were junk so I sold him my left over 31" tires and we hacked the fenders up to make them fit.
Last by
Miko Hall, on Flickr
It Sat long enough to start 1 of those Jumanji plants.
Mechanic is a little husky
Last by
Last by
Last by
Last by
Last by
I haven't got as much done as I wanted too but it's still crawling along, I got the bottom side buttoned up enough to roll it back upright.
Hole
Progress by
No hole
Progress by
Grinder skills
Progress by
Progress by
Eh, I discovered a lot of the horrible welding went away when I changed how I was grounding my welder, I stuck a bolt through a hole and blasted the paint off.
Progress by
This still needs a lot of work but it can wait.
Progress by
only picture I got of the bottom after welding all the patch panels in, Jenn running the pressure washer, I haven't had much help with previous projects but she helped a lot with the shop crane and hopefully the rest of this IHC. We
pretty successfully built an 'off road' shop crane. I used 10'' swivel wheels and 8'' solid wheels and welded up some brackets to bolt them to the crane in the same manner the factory castors did so I can easily swap back to the way it was if I need to lift more weight- since the new wheels have a significantly lower weight limit.
Off road shop crane by
Moved by
Moved by
Moved by
Even through this ridiculousness it rolled!
Moved by
Move by
It's going to be a real PITA getting all this to fit in the 48
Last by
