1 - 19 of 19 Posts
'95 Blazer 4X4
Hello,
I have a 1995 Blazer 4X4 with the 4.3 CPI engine and 118,000miles on it and it is behaving very strangely. When the weather changes or is damp/cold the engine misfires at idle and is very audiable. This is not a problem once it is brought off idle.
It also will just cut out for a half a second or so going over hills at about 50-60 miles per hour and it will repeat it several times and then clear up. Sometimes it will not do it at all.
The service engine soon light comes on every once and a while but not usually.
Does anyone have any idea what the problem is? This is a good blazer and I have had it since 19,000 miles and this is frustrating.
Thanks a lot
I have a simular problem I've narrowed it down to a leaky(driping) CPI. (i think)
let you know as soon as I change it probably around 1/2/04
I finally got blown
check local gm dealer for recall--read in diff post about this.
the first time they look at it they try to clean the injector assy, then if that doesnt do any good then they rep the assy.
call first --if there is no recall you will have to pay for checkout.
Also how long has it been since you did a full tuneup(cap/rotor,wires,plugs,filter)?Worth a try,along with using Seafoam to clean fuel system,before diving into the CPI.
'95 Blazer 4X4
A new cap, rotor, plugs and wires were done at about 102,000 (16,000mi ago).
I dumped Fuel Injector cleaner into it yesterday and drove it about 45 miles with no improvement noticed.
My service engine soon light was blinking as I was coming home and the next time I went out, it stayed on solid. After getting in the throttle to merge into traffic, it shut off but the symptoms were still there.
When it is running bad, the exaust pipe smells like it is running very rich.
Clean N' Dark
I would go to Autozone or the dealer and get your codes read.
Sounds like you have a sensor acting up. Everytime the engine light comes on, a code is stored in the computer.
It could be the CPI but the CPI doesn't kick on the service engine light.
man, not to sound all passimistic (sp?), but i was already there before and i know the symptoms. I replaced the car, rotor, spark plugs, spark plug wires, fuel filter, etc... Basically, a full tune up. heck, i even ran sea foam before all that. ran a tiny bit better. But after the next oil change, it was getting worse. so i pulled the upper plenum and saw washed gas on the manifold, thus the culprit being the CPI unit and nut kit.
Clean N' Dark
Xtremejimmy, we are not solving your problem, we are solving the thread starters.
If he is getting check engine lights, the smartest course of action is to get the computer checked to narrow it down before the engine is torn apart.
'95 Blazer 4X4
Discussion Starter · #16 ·
The computers already been checked several times and not cleared. It has read anything from O2 sensor curcuit low (only the first time) to just the knock sensor curcuit being low. Otherwise it is not causing codes. I guess it must be the CPI unit.
Clean N' Dark
Those are codes if you are getting something read by the scanner.
Sounds like a lean cylinder bank.
Which bank was the knock sensor acting up on?
goldduster318 said:
Hello,
Thanks a lot
how many miles on those plug wires?
sounds like a burnt plug wire. which will cause it to miss under load (going up hill). when my 95 did this, it wouldnt do it all the time.
1 - 19 of 19 Posts
