Here is the beef. I've been having this intermitant Code 32 (EGR on fuel injection). I have done this , Replaced with Original Factory GM EGR for stick, new gasket. New exhaust header,O2 sensor, and gasket and doughnut seal. What else should I be checking? I've checked all the plastic hoses that connect to the EGR and around the Injection unit. All are solid and non leaking. Its starting to piss me off.
ASE certified MasterTech
Have you checked the EGR solenoid?
Sounds like you threw a lot of parts at it!!
If that is the device that has a vacume line going to the EGR itself, , it too has been replaced.
What else am I missing here? I'm so scratching my head over this.
