1996 Sonoma SLS RWD 2.2L MT Reg cab, 70k miles.
Future, full-time daily driver.
Summary. This is a long ramble/rant. Currently raining outside where the relevant truck is. However, if you found this thread through search, the photos might be somewhat helpful if you want to understand drainage on the right, front side of the cab, assuming you do not already. You can skip the text and just view the photos, also.
I found rust in the inside, right, front, cab corner, above and below the electrical "bulkhead" connector. Super disappointed as I had grill, bumper, and inner fender out last year, as well as the carpet removed. Spent at least a couple days cleaning the extremely dirty interior. Did not notice this at the time. Venting a bit, but the photos may help others when they are trying to understand water drainage and the sheet metal structure of the cab in this area. Remember, the electrical bulkhead connector on the right side is relocated to below the fresh air damper in later years.
Wide-angle view of R, front cab interior. Bottom of fresh air damper assembly is the black plastic with triangles, slightly above center of photo.
Close-up view of R, front cab interior. Sealer rust-jacked. Fresh air damper is to the left, on the "firewall", a few inches higher. The right, plenum drain is directly above and little left of the yellow, circled area, on the exterior.
Lower, wide-angle view of R, front cab interior. The sealer applied left and right is at the bottom of the "firewall"
Lower, close-up view of R, front cab interior.
Wide-angle photo I found on S10forum showing exterior of the area shown in previous 4-photos. Use the bulkhead connector as a "landmark" to understand relationship between sheet metal on outside and inside. Note portion of blower motor visible above wheel, mounted in the HVAC / evaporator enclosure. With fender in place, the area forward of the door in the original red paint area, is partially blocked with a rigid foam seal loosely fixed in place, until it disintegrates or is chewed up by rodents.
Close-up photo I found on S10forum showing exterior of the area shown in first 4-photos. The opening above the bulkhead connector is the right drain for the plenum. The fresh air damper assembly is an open-topped box with dampers, directly above it that allows the HVAC control panel to select between recirculation or fresh air. Debris entering the plenum and cowl gutter through or past the cowl trim can flush through the drain; get "sucked" through the blower motor to be deposited on the inlet side of the evaporator; or become lodged in place to rot away your sheet metal and help water find seam/seal failures to enter the interior of the cab.
Back to my truck. Exterior, wide-angle view of top, rear of right fender. Right, cowl trim piece removed. Just to the right (from perspective of this photo) of the hose nozzle, under the middle cowl trim, the plenum drops down to the fresh air assembly and associated sheet metal enclosure. Super difficult to access, but a small diameter wet/dry vac hose can be snaked down to that area to remove debris. I have not found a way to access it through the blower motor opening; too little room. Then, water flushing can be used to hopefully push the remainder out the drain.
Closer view of top, rear of right fender. Notice all the painted seam sealer. I believe that seam extends to the bottom of the cab. Also notice the intact foam fender seal. This area does not really drain into the plenum, but straight down, past the drain opening by the bulkhead connector, to the bottom of the fender.
Very close of view of seam sealer below bottom, right corner of windshield. Dry and cracked, as it is below. Could not get photo of seam sealer below, but could see it poorly by prying foam block back going through the door / fender gap.
~30 minutes with a garden hose applying water in multiple locations from roof above door to middle of cowl trim did not yield any interior leaks. I can see no obvious, old water “trails” on the inside. The carpet on the right side of the cab was damp, not soaked, when I pulled it after purchasing the vehicle July 2020, but the floorboard was very corrosion-free. Carpet and the insulator pad at the bottom of the firewall, right side, have remained dry AFAIK. There was tons of debris behind the blower motor and evaporator; in the door hinge areas; in the back of the fenders; and in most of the cowl gutter / plenum. I spent hours cleaning everything out Fall 2020 and water flows freely since. The right (and left) door, drip weatherstrips were replaced with the windshield a couple months ago.
I suspect the rust we see on the inside is the result of normal degradation of the seam sealer on the exterior, and probably previous accumulation of debris that obstructed drainage and maintained a damp environment. I wonder what the plenum area looks like behind the drain, below the fresh air assembly. I noticed no rot on the front of the firewall in that area when I had the inner fenders out. Do not have the motivation to properly address this right now. I think I might use a nozzle extension to Fluid Film the exterior opposite the rust visible inside to slow the rust until/if I am ready to “fix” whatever is rusted.
