Status
Not open for further replies.
41 - 50 of 50 Posts
97 cavi starters will... look on o'riellys auto and you can get most parts interchange info. As long as its the same part number lol
Which year model Envoy interior door handles would fit a 2003? Im noticing quite a difference on the years. Great idea btw. Horribly tedious rooting around old threads to answer one obscure question.
· Forever breaking this S10
The seats are different between S10s, Sonoma, Blazers, Jimmys, Bravadas, and Envoys.
As long as they are all the same style (bucket-to-bucket, 60/40-to-60/40, bench-to-bench), they'll all bolt up, but the seats aren't identical. TokoDragon can tell you about this. They have a different pattern on the seats between the brands and the foam underneath is actually different, too.
Buckets will bolt up to buckets and 60/40 seats. 60/40 seats will bolt up to 60/40 seats and buckets. I'm unsure of bench seats, but I believe they'll bolt up to all seat styles, but nothing can bolt up to bench seats without modification. This is talking strictly no modification at all, bolt right in seats.
Seats from the same generation at least are all interchangeable. I started with 03 ext cab Sonoma SLS buckets, switched to a Hombre reg cab bench, then found an ext cab (reclining) bench. All bolted right up. Mines 03, unsure year of reg bench(96-99?). ext bench was a 99 S-10.
My .02 seen as it was just commented on...
You can swap the hinge where the handle is only if you want to go from non recline to recline it should be 4 bolts f I remember correct hell of a lot cheaper at the wrecking yard buying a hinge than the whole seat.
All models are the same frame given their style 60/40 bench or buckets. The foam is unique to fit the covers.
If you are daring and tear one down to the frame and see a plastic guard piece on the back frame attached with zip ties it is not supposed to be in this country those were for exports only.
I worked in the Factory assembling the seats and doing QC on them from 1995-1999 up to 550 trucks a day. depending on the order. We also did the GM minivans same place separate line.
If you like your heated seats ... then you are welcome :cool:
If you did a blazer swap and have a console note that there are a few ridges on the inside towards the top side as you reach into the console that is where the Coin holder mounts to it slides straight down so if you want that accessories look in the yards it was one of my favorite features on the blazer when taking a toll roads back when .35 cents got you through a toll. http://i.ebayimg.com/00/s/NTY1WDEyMDA=/z/0BMAAMXQVT9SyLBH/$_57.JPG
41 - 50 of 50 Posts
Status
