you sir are the shitwell i work at a GM dealership and i have online access to the service information (si ) ill do some researchin and get this info asap
do you still work at said dealership? i was just tryin to find the lower rear shock mount plates, and cant get them anywhere new.well i work at a GM dealership and i have online access to the service information (si ) ill do some researchin and get this info asap
All the Hollanders (book and computer) I've used haven't had straight swaps. Just what the factory interchange is.Its more or less been done.
It's called the Hollander Interchange manual. Used to be a REALLY expensive book that pretty much only wrecking yards had - but there's an electronic version of it now (of course!). Trick is to find someone who has it!![]()
if yer not stuck on 'brand new' anyone who bags their truck should have a set, i know mine are layin around the garage stilldo you still work at said dealership? i was just tryin to find the lower rear shock mount plates, and cant get them anywhere new.
this is true.as for things like steering wheels, its dependent on the splines of the column/wheel that should effect it correct?
