1 - 20 of 83 Posts
Self Portrait
OK First Gen'ers, when I bought my truck used there was an unidentifiable substance in the bottom of the map pockets that had successfully chemically bonded some pennies to the bottom of the pockets. Since they have that fuzzy stuff on them cleaning them was almost out of the question. Besided, my wife think that they make excellent junk collectors! Well I'm doing away with the pockets and I'm going to be doing it as inexpensively as possible. I am going to be taking lots of pictures so I'll post them here so you all can follow along. This is interactive so if you have any questions or comments, fire away.
The first thing that you will need is 18 (9 each side) of the plastic panel retainers as you are going to break them taking the door panel off. I paid $.35 each for them at a local auto upholstery place.
Long Bed Member
HAHAHAA! but yea id like to know mine are useless and have pennies stuck in them too (hmmmm factory option maybe?) so keep us posted
Self Portrait
Pull off the door panel!
Take the two screws out of the door handle. If you have manual windows you have to get the window cranks off too, this requires a special tool, but while your at the upholstery shop ask them if they would pop them off for you real quick....don't forget to tip the guy is he doesn't charge you! (tips count, you'd be suprised how fast I get helped at the shop I go to!!!) Now just pull the panel away from the door frame. If you have power windows be careful of the up/dn switch wire the wire is attached to the door and the switch is attached to the door panel. Once you have poped all the plastic retainers lift up on the panel and it comes right off.....remember there 9 per door.
Self Portrait
Peel Off the carpet and take the carpet backer off!
LAy your door panel on a solid work surface. Grab that nasty carpet that covers the map pocket at one corner and pull it off the door. You'll notice that there is a black plastic backing that is under the carpet. This plastic backer is attached to the door panel by melt-down plastic rivets, about 18 of them. Take a center punch and punch a small dimpel in each one of the rivet heads, you may have to rub off the carpet fibers to find all of them. DO NOT DESTROY THIS PLASTIC BACKING PIECE!!! We will use it later. Once you have the heads dimpeled drill them out with a 3/8 drill bit(or as big as you have.) It's no necessary to go all the way through.
Self Portrait
Discussion Starter · #5 · (Edited)
Now take off the pocket
Unlike what is shown in the picture above, the pocket doesn't come off with the plastic carpet backing. There are 4 more Melt points to drill out to get the pocket off. Drill these from the back side.
Self Portrait
The pocket is off!
Here is a pic of the pocket that is removed with the rivet locations indicated.
Self Portrait
Discussion Starter · #7 · (Edited)
Here is the Naked door panel
OK, the nasty pocket and the ratty looking carpet are off. In the next series of pics I'm going to cut a melamine backing piece. Mark and attach some tee nuts to the backing piece. Pad the backing piece. Stretch some left over silver vinyl over the padded backing piece. Attach the covered piece to the door panel then reinstall the panel on the door with our new retainers. I'll have these pictures up as soon as I get the work done, I am out of glue at the moment but I may go get some tonight. This is just the passengers side, if you guys are interested I'll do a custom speaker pod on the drivers side. Let me know!
Beyond Basic.
sweet i hate those pockets, and it also makes your truck look custom somewhat, hehehee
Self Portrait
Discussion Starter · #10 ·
A little more prep work
With the door panel naked I decided to give it some clean-up and paint the plastic piece around the door handle and switches. So I used a lot of 409 to clean up the panel then removed a plastic hump where our new backing piece will lay. Here is the hump.
Self Portrait
Discussion Starter · #11 ·
Hump REmoved
Here is a shot of the hump removed. You'll notice that the panel is upside down in the picture, as it was in the last picture. Sorry if this was confusing.
Self Portrait
Discussion Starter · #12 ·
REmove the arm rest
Now remove the arm rest so that you can clean under it. All you have to do is push it in the direction of the arrow on the picture. Mine was snug but a pop on the front with the palm of my hand in the direction of the arrow made it come right off. It was nasty behind there!
Self Portrait
Discussion Starter · #13 · (Edited)
Remove the trim panel
Edited!!!!!!
To remove the trim panel to paint it you have to remove the 6 metal retainers. After having struggled with mine for about half an hour I have decided that the only way to get the retainers off safely is to snip the ends with a pair of diagonal cutters and put new ones on to reattach the trim piece. After their off, pop out the trim panel, sand it, spray it the color you want then put on a couple coats of clear to help protect the color coat. Here is a pic of the retainers. I will have more to say about this later in the thread I just don't want to be hopping around different subjects.
Self Portrait
Discussion Starter · #14 ·
Here are the pennys in the pocket
This is why I wanted to get rid of the nasty things! YUK!
For those of you that do use your door pocket, but you want it to look like new or custom paint it red or something unique, there is interior car paint.
Self Portrait
Discussion Starter · #16 ·
Kropelin, on first Gens the pocket is lined with this fuzzy crap and you would probably have to use fiberglass resin to smooth it out before you could paint it. And we will be using the area where the pocket is to put a speaker pod to hold something a little more exciting than a map of Detroit! Maybe some lights too....who knows...we're just having fun here and we'll see where it takes us. Your input is always welcome! Stop back often.
Self Portrait
Discussion Starter · #17 · (Edited)
Here is the Vinyl
This is the left over vinyl from a project my wife did. She picked up a yard of the stuff from the fabric store for $4.00 as a remnant but you only need a yard and the normal cost was about $8.00.
Self Portrait
Discussion Starter · #18 ·
This is the hardboard
I had to buy a 4'X8' sheet of 1/4" hardboard because my local Home Depot was out of the smaller pieces. If you can find a 2'X4' piece, it will work fine. The cost for my piece was $10.00. You don't really have to use hardboard, if you have a piece of 1/4 plywood it will also work. We will also use some of this when we build our speaker pods so try to waste as little as possible.
Self Portrait
Discussion Starter · #19 ·
Trace the backing piece
Remember me telling you not to destroy the plastic carpet backing piece? This is where we use it again. Lay the backing piece on the hardboard. I lined mine up in the corner to minimize the cutting that I had to do. Trace the outline of the plastic backing piece onto the hardboard. You will have to make up for the missing piece where the pocket use to be but that is easy, trace as much as you can then connect the missing part of the line with a straight edge. I just used the flat part of the backing piece to draw my straight line! Don't forget to trace the inside vent opening if you are keeping the useless vent. If you want to get rid of the vent just cut the vent off of the door panel and don't cut out the opening in the hardboard and it's gone!!
Self Portrait
Discussion Starter · #20 ·
These are the tools you use
Here are the tools you need to cut out the new backing piece. A scroll saw with a fine tooth blade, a drill with the biggest bit you have (not shown), safety glasses and a dust mask. The hardboard makes lots of dust when you cut it and you haven't lived until you have had to hack up a lung after breathing that crap! Use the safety equipment! You can also see part of the traced line on the hardboard in this shot.
1 - 20 of 83 Posts
