I just got an Auto Metter Tach ... My 98 s-10 doesn't have a stock tach in the cluster, so where should I wire in the new one?
Should be a white/gray wire from what people have said. Make sure that if you are hooking into your stereo wire for power to hook into the accessory wire and not the constant because you will have a battery drain then.waterboy14020 said:look under the cluster where it plugs into a harness...there should be a wire that is white that does not connect to anything, that should be your signal wire and then just hook up your pos neg and ignition to your radio signal wires
