1 - 2 of 2 Posts
Is it very hard to install a overhead console in a Blazer that does not have one. What about getting power to it?
Never-Ending Project
It's too easy. I ran the dome light power from the factory dome light, and power for the lamps and compass/temp from the lights in my mirror (any accessory power will do). You can use the mounting holes for your old dome light to hold up the back, and just stick something above the headliner and put a screw into it for the front (I used a 4"x2" piece of plywood, doesn't stress it at all). If you're putting in a 2nd gen console with the temp sensor, you'll need to install one and wire it in, and run a wire to your VSS. I'll have to double-check the wires for that. I've got a feeling Rlith might beat me to that explanation.
1 - 2 of 2 Posts
