rice-R
sup, im about to get some drop leafs and i was wondering about my left side leaf..the bolt seems to be in the way with the gas tank so i was wondering how can i take off my leaf /install it?? maybe im jus not looking hard enuff but from what i see it looks like i may have to cut the bolt? is that good?? did anyone else have to drop their gastank to put their leaf on?? :bah: thanks and sorry if it dont seem like i know anything hehe:p
On my 96, I removed the nut, slid the bolt in far enough to cut the head off, and replaced it with a new metric bolt from the dealer, head facing out. I have heard that the bolt can be removed with loosening the tank strap bolts enough to slide it past. I also saw one article in a magazine that with a hoist and the leaf hanging straight down, they pulled the leaf toward the outside at the bottom enough to slip the bolt out. If you have access to a die grinder, I think cutting the head off is easiest.
little pink pink
Thats what I did...I cut the bolt head off and it came out.
twisting the leaf would be alright...I don't think you would hurt anything...and if you did..your going back with new leafs anyhow!:rolleyes:
ho sup man, well thats pretty much what i did loosen the straps and get a big 2x4 and bent the $hit out of the tank until the bolt have enough space to come out. i could coem down and help u the day u do it if im free.
Project ZO6 S-10
I was going to cut the head off when I put the urethane bushings in, but I couldn't get a replacement bolt from the dealer so I got it out as far as it would go then I twisted the leaf with a ball joint seperator. then I put in in from the other side.
Make sure you can get a replacement if you are going to cut it.
