Long Bed Member
looks way better then the bumper painted or not
frame layin member
looks alot better i'm getting mine painted and installed next week. what kind/size bolts did you use to put it on with?
formally Lownoma
since my truck was a 97 it had the molding that covered the corners of the bumper..not like the newer ones...but anyways the 7mm bolts i took out that held the moldings on is what i used....they worked good..as far as i know all the beds have the holes predrilled for the rollpans and match right up if you use a factory gm pan...there were 5 across the bottom of the bed and one on each side of the rear quarter panel....hope that helps
later
jason
frame layin member
thanks man.
