Discussion Starter #1 (Edited by Moderator)
I took the factory HU out and tried to install my aftermarket one in using the same kit i used in my 98 dash that said it fits 98 to 02 but it doesn't fit in the doner 2002 dash. The kit is too wide. Here is a picture of the factory one I took out. Does anyone have a suggestion for an install kit that will fit the hole left by this HU?
Thanks in advance.
Jen
Sent from my iPhone using Tapatalk Pro
Here’s the one I used to replace that exact radio. Metra Electronics 95-2001 Double DIN Installation Dash Kit for Select 1990-Up GM Vehicles https://www.amazon.com/dp/B003D3NEEU/ref=cm_sw_r_cp_api_i_dgnQEbV021FNY
Metra 70-2003 Radio Wiring Harness For GM 98-08 Harness Amazon.com: Metra 70-2003 Radio Wiring Harness For GM 98-08 Harness: Car Electronics
I have a single din HU that I want to put in. I wonder if they have something for that? I'll look for something with these parameters but single din.
Thanks.
time to get cereal
The kit for a 98 won't work because it's a proprietary size. Your '02 is double DIN. They changed mid-2002 IIRC.
