Hope someone finds this. Is there a seal that can be replaced on the input bearing that is accessed without disassembling the transmission, perhaps on the retainer? My current tranny with 205k on it has bad synchros so I found a donor trans for $100 near me and picked it up. Donor is wet all over, output seal definitely shot, bell housing is soaked inside and out. I can’t tell if it’s from a bad rear main seal from the original engine or a bad input bearing seal. If it’s possible to replace just the seal that would be amazing. With the tranny swap I will be replacing complete hydraulic clutch system, clutch, pressure plate, flywheel, pilot bushing, output seal.
