hold throttle to floor ....
Want that make it flood more?hold throttle to floor ....
Holding the pedal to the floor on a fuel injected vehicle shut off injectors and put the engine into "clear flood mode."Want that make it flood more?
Thanks,but it's still leaking down in a few seconds.So that is one problem.Check to be sure the temperature sensor is working properly. Using a scanner to read the temp from the computer is the best way. If that sensor is faulty it will flood the engine when warm. If it reads -40° when the truck is warm it's your problem.
Some trucks have a sensor and a gauge sender separate from each other. The one with 2 wires is the one to be concerned with. The other just runs the gauge, period.
Thanks,I'll see if I can find another mechanic.Thanks,but it's still leaking down in a few seconds.So that is one problem.
