If not, then you could always buy after market injectors. They are just the Bosch style if I am correct.
Now what size?:confused:
A trubocharged 2.2L is goig to put out something like 750hp right?:D
SO you should use 75lb/hour flow matched injectors:rolleyes:
...But seriously you can just use the standard Bosch style performance injectors if STS is not including any.
Yeah, i figured aftermarket injectors would fit no problem, but then we'd need to reprogram the ECU for the injectors. I'm not sure how may turners are avaliable for that. If we knew how much the stock ones flow, then we'd know when to stop making HP... at least i'd hope.
G
venom makes performance injectors for the 2.2 i think they are controlled by a sepererate module that is included with the injectors
