Hello,
I have an 88 s-10 with a 2.8 and tbi 2wd. I don't have the label that should be under the hood with the ign. timing specs on it. I have figured i'd check out the local junk yard, but all i found were 2.8s in 4x4 blazers. and i don't know if the 4x4's would have a different timing then a 2wd. so i called up a garage and i was quoated 6 degrees by a secritary that asked a machinic that works in the shop. So i'd like to run it by you guys to see if anyone as the same truck as me or had and knows what the timing should be.
Thanks,
Fox
life begins @ 20 psi
I have the EXACT truck that you do, except mine has a 3.4 now :D. That mechanic told you a fib as the timing is supposed to be set to 10 degrees BTC. HTH's
Mike Campbell
