1 - 10 of 10 Posts
'Bagged Super Sport
I currently bagged my truck with the F9000 bags in the rear, but my stupid @$$ put the bags behind the axle so now it dont go as low as it should. If i put them in front of the axle how much lower u think itll go? Any difference in ride quality? And anyone have any idea why my truck is .5" higher in the driver rear?:boom:
The Researcher
Mmm
The F9000 are pretty big bags for the S10's on the side, they will work though. U are using the beside the frame/over the axle kit?
I'm not too sure if they will fit infront, never installed any up there.
Check you truck all the way down and see it the bags are stopping on there built in bump stops or something else is hanging the truck up.
The rear leaf hangers swing backwards and hit the frame a lot of the time. U may need to notch there as well.
amatuer porn star
it may not be just the bags... take a look at everything underneath to see what might be causing it to hang up.
Could also be the leaf i think thats what mine is. I can still push down on it after its droped and itll move.
'Bagged Super Sport
im using the air ride underframe/air over leaf mounts. i switched it to the front of the axle this weekend and got about 2 inches lower that way. Now i have to redo the front end, pain in my @$$... It makes a really loud bang when it drops below 40 psi and the left front slams real low. I think its the way it sits in the coil pocket, anyone have any suggestions?
'Bagged Super Sport
Im running the regular 2500 bags in front btw...
The Researcher
Well
Just make sure the cup is sitting nicely in the pocket when you jack it up and bolt the front back together. Also make sure its bolted in securely. If its good when it goes in the first time you should never have a problem from t here.
Also make sure the mounts are facing the right direction and check to see if anything other then the bags and mounts are hitting themselves together.
I get a loud bang to but thats me bouncing the crossmember off the ground lol.
i get more of a pop and the fbi rep said it could be that its not mounted securely and that i should cut the bottom of the spring pocket in the a arm and tighten it up....Oddly enough it pops on both sides and seems more like its catchin on something but i havent seen any rubbing
amatuer porn star
the ones from FBI are adjustable to get the bag properly aligned in the pocket.the do make a slight pop noise when your pop it up
1 - 10 of 10 Posts
