I was going to say the same, except I've already got a set of those grotesque wheels!Get rid of those gross Zr5 wheels and give them to me.
Welcome to the forum. Nice looking truck from what is posted so far. Please post more info about the truck when you can.
Thanks man thinking of changing out the tires I have on here to some big mud tires.Get rid of those gross Zr5 wheels and give them to me.
Ok thanks man and will doWelcome to the forum. Nice looking truck from what is posted so far. Please post more info about the truck when you can.
Yup it sucks to live in North Dakota 😀Yup! The old "Didn't get the lower tabs in right" headlight error.
I see snow in the pics. The box sides, rockers and cab corners are going to gradually get worse.
Good ole salt.
Those are just the factory fog headlamps. Nothing like the Envoy's.An 03-04 GMC ZR5 has a much cooler front end if you can find one. With the Envoy style lights and one piece bumper and valance design.
Fix any rust like you really mean it. I live a 1/4 mile from the ocean, salty air, salty roads; I run different trucks summer and winter, and have run mud flaps on my winter trucks. Fronts keep the sand from blasting the rocker paint off and packing the body mounts with sand, rears prevent the frame rails and rear bumper from getting packed with salty sand and rotting away. Not to mention it packing up around the brake and fuel lines and rotting those. Makes all the difference to keep the sand from packing inside everything, gives your truck a fighting chance. I tossed the molded "custom fit" ones, and cut a flat set from some semi-truck flap material, so it extends in as far, and up inside the wheel well, as possible and doesn't stick out and look like *hit. If you already have mud packed up in there, it's worth pulling the bed once to clean it all up and get a grip on it before it's too late. AWDirect has the flap material; CRC makes a great marine grade waxy undercoating.Yup! The old "Didn't get the lower tabs in right" headlight error.
Good ole salt.
Well it's a GMC, sooooooo yeah. They don't look much like the Chevy stuff in any variation. And I don't think those lights are ZR5 specific either.Apparently the 03-04 GMC ZR5 has it's own headlights half way between S10 an Envoy.
They are definitely not the 2 piece S10 headlights and turn signals. W/ or w/o fog lights.
Also lot nicer bumper arrangement than the cheesy S10 setup.
If this was yours what would you change
Firstly, I believe 2nd Generation years are 1994-2004, FYI. So, this 1st gen subforum is the wrong location.If it ain't broke don't fix it.
