1 - 10 of 10 Posts
StepIntoTheDark.com!!!
Ok... I kinda feel like I've hit a wall...
I've modded my truck about as much as I can without tearing into the engine, what should be my next project... I am thinking Cam, Roller Rockers, and springs, please help me out...
Thanks any input is appreciated...
2001 Onyx black Xtreme 4.3 ltr V6 Auto
Performance Mods so far:
K&N generation 2 intake
9 inch K&N filter on the end
MSD Digital 6 Plus
MSD 8.5 wires
Throttle Body Spacer
Flex-a-lite #60 electric fan
ASP performance crank pulley
Granetelli MAF
Lakewood Universal Traction bars
Flowmaster 40 series w/ dual 3 inch dumps
Hypertech programmed
160 degree thermostat
Flex-a-lite transmission cooler
NX Nitrous GM EFI kit
2 inch y pipe
Catgo High Flow cat
JBA Headers
Appearance:
Non APC Projector headlamps
diamond Clear corners
Gen 3 altezza's
SS sport mirrors
Gen 1 cowl hood
Billet grill
Exterior emblems shaved
Xtreme emblems on head rests
Painted vents
Tinted windows 5% on back 25% on sides
strobes in the corners
295/50/15 BF Goodrich Radial T/A's in back
225/50/15 BF Goodrich Radial T/A's in the front
15x10 Weld prostars in back
15x7 Weld prostars in front
Tailgate handle shaved
Get a sun-roof!!
Sounds like it's time to do some port work. A little grinding here, alot of grinding there, and some spit and polish on the way out.
What kinda 1/4 times are you running with all that crap installed?
Oh, and I didn't see it on your list, but if you haven't already you can grind the restrictor plate off of your throttle body butterfly, and also relocate your air temperature sensor. :thumbup:
This advances the timing...
oh ya and about 1/4 mile times I don't know, I've done most of this work over the winter and haven't run her yet, but I will soon..
Well there good buddy here is what I would do... wait this is what I am doing. 1.6 roller rockers I have the crane gold, but you dont have to get the most expencive. Cam either camp/Crane both real close I am running one with 276/270 dur. this will put the power plant at 2000-5500 rpms. COme new springs to match your lift. I would do a Stall like 2500-3200. Probably a new torqe converter they make a Nitrous one. Port and polish the heads wont hurt any either, but I would drop in some forged pistions first. Then maybe a crank to finish the bottom end. If yo still have some money left hone out the throttle body and if for some reason you still have money have the PC sent out to match all the work you just did. Happy track to you
1 - 10 of 10 Posts
