Is this hard to do ?I have a 96 S10 4.3L auto vin X
I dont wanna pay $120 labor to have them changed when they cost as much as they do and i have to buy 3 of them.
What part of the truck are they all on? I know one is past the cat but what about the others?
Can someone walk me through this?
Anybody?
THANKS!
Insane Network Engineer
should be 4 of them, on on each header, one just before and one after the cat.... Just use the proper sized open mouth and mebbe tap on the wrench with a hammer to loosen it up... Depending on how your exaust system looks, you might need a little penetrating oil
So they are easy to reach and remove for the most part?
Anything i need to do after the install? Like take the negative off my battery or anything?
THANKS
Early Member
You would only need to disconnect the battery after the install, if there were trouble codes indicating your O2 sensors were faulty.
Project: Sabriel
there's 3, i believe. ome somewhere on the manifolds/y-pipe (never looked for it), one before the cat, and one after. there's also no reason to replace then unless they're throwing a code or the engine is running lean/rich.
Discussion Starter · #9 · (Edited)
Yeah the cat has been checked and is fine...
"If you want better gas mileage do a tune-up and regularly check your tire air pressure."
That i already have done and do do so this is just another oem replacment that may help out in mpg area
