To begin with I am new to S-10 Trucks. My neighbor has a 1988 ??? S-10 Tahoe pick up for sale.
It has been setting for 2-3 years in his driveway.
It is not rotted out...just a few small rust through holes in the bed. It has not been started in 2-3 years. The interior is decent.
My question is...What is it worth ?? And is it worth fixing it up...What are the drawbacks to this model ??..and am I getting in to a never ending money pit ??
Any and all thoughts will be welcomed.
THANKS STEVE---OHIO
THANKS STEVE---OHIO
OHIO...sounds like a rust belt truck. Get under it and check the frame...throughly.
Smack the sides of the frame with the round end of a 2 lb ball peen hammer on either side of the welded seam in the frame. Directly below the rear of each door. Bet it punches right thru. If the frame is good it'll bounce off. Hit the same spot a couple times on each side of the truck.
I'm in the salt belt and I've got 2 frames that are10 and 12 years newer and it went right thru both sides of both. Salt gets inside and no matter how well you wash the truck you won't get it out. You'd need to submerge it in a baking soda solution after every trip in the winter to neutralize the acid salt creates.
Holes in the bed indicate serious rust issues.
Reactions: S15E83
THANKS STEVE---OHIO
You've come to the rite spot for opinions. A garage kept lo mile Arizona unit is usually ok.
