i need to know who, if anyone, makes a relatlively cheap 2-3 inch suspension lift for a 99 ext. cab sten....if anyone knows i would really appreciate it....
NO NO NO NO NO NO NO NO!!!!!!!!!!!!!!!!!!!!!superlift has a torsion bar 2 inch lift for around 400 bucks or you could crank the t-bars up in the front and add a shackle in the rear. the truck will ride rougher and may cause the cv's to wear faster.
why did you dig up four old threads to ask one question?Sup guys.. I need some help as well.. i have a 98 that is starting to be a like a problem child from hell.. i just put a 6" Superlift and 33" tires now i am starting to feel a little lag when taking off.. i am thinking it either needs new gearing in trans or rear end or maybe both with a new motor.. does isn't the 4.3l good as well as the Trans.. any idea's.
you need gears
rear end gears, like 5.74x4 said atleast 4.11 but 4.56 would give more power back, but your mileage would suffer, it a give and take kinda thing.yo.. thanks for the help so far.. when you say gears you mean in the trans or in the rear end.. this is all new to me.. i had no idea that more needs to be done then just adding a lift.. lol.. i am now starting to understand more and more each day..
You need different gearing in your front and rear differentials. I believe you'll be limited in gear choice. The lowest gear I could findfor the front IFS 7.25" diff are 4.10:1 but I could be wrong. You're gonna have to do alot of research and it sounds like you'll be taking it to a pro to have the work done. Check with http://www.gardenstatemotorsports.com/category.sc?categoryId=78 or http://www.rockauto.com/catalog/raframecatalog.php?a=G-moog or http://www.summitracing.com/ for parts. There are alot of other places too.Quote: Originally Posted by illgetit Sup guys.. I need some help as well.. i have a 98 that is starting to be a like a problem child from hell.. i just put a 6" Superlift and 33" tires now i am starting to feel a little lag when taking off.. i am thinking it either needs new gearing in trans or rear end or maybe both with a new motor.. does isn't the 4.3l good as well as the Trans.. any idea's.
