amatuer porn star
my truck is now fully bagged it lays frame really hard all the way around....my shocks that were in stalled when i first got it lowered(3"-4") are now too long.
im gonna get some toxic shocks for each corner only problem is i dont know what size.....anybody have any ideas?
i gotta get the relocators also:thumbup:
amatuer porn star
Discussion Starter · #2 ·
anybody????:bash:
amatuer porn star
somebody gotta have some ideas..:bash:
Un-Blown Fake ZQ8
I used the application chart at http://www.toxicshocks.com/pages/chevyapps.html
the fronts were way to short even though I chose the right ones (right ones according to their chart).
I suggest you go through the trouble of using ToxicShocks lengths page at: http://www.toxicshocks.com/pages/lengths.html
and figuring out definetly what length shock you need. Maybe use the current shock you have to compare and make measurements from. Good Luck! Hope this helps some.
btw if you need 411015 I have em, they say they are for a 3-4" drop in front w/ spindles and springs, but as far as I can tell they are for a 3-4" drop w/ just springs. I stuck the shocks into position to see how high the a-arm would have to go to tighten the shock down and it was 2" or more. lol. So howabout $30 each plus shipping :)
later.
amatuer porn star
thanks for the help .ill take a gander at the chart
www.AcrophobiA.net
i have doesch tech shocks on mine.....im pretty sure they are like struts in front and real shocks in back........you can call STS at 310-632-9854 and ask what they use for their trucks
Mini-Truck Convertee
later.
I know this is an old thread, but I am just bumping it with the correct info as it is the first one that came up when I did a Google search.
StylinTrucks has the 411015 labeled as 2"-3" coil drop, which is incorrect. I just tried installing them, and they are way too short. Basically, I would need to compress the spring in order for the dog bone to be under the LCA. This is a bad idea because I would have no extension travel, and the shock would rip itself apart on the first bump. You would probably need a 4" coil drop in order for these to work properly.
I am going to have them replaced with a pair of the 413515, which measure a lot more like the Belltechs I am replacing with these. The 413515 are labeled as being for a 1" coil drop, but should work fine with a 2"-3" coil drop.
i use 91 nissan hardbody pick up truck shocks 2wd. they work fine.
Can I get a hot tub?
^this is what I always heard reading before I bagged. I have a set waiting to go on the front once I tear it down to lay the front out.
