I have an 83 s10 and I just put the heater core in. I took pictures of the way the switches were wired, and the way the cables are connected, but I didn't get a good enough picture apparently to rewire it 100% correct. I need to know which color wires belong on which prongs.
Is there any chance one of you fine people can pull the heat/ac controls out enough to snap a good picture? Especially the AC switch in the back of the control head that actually turns the compressor on (not the slide knob). I would appreciate it. I've got the car back together and this is all I need to finish it up.
If you've never done it, its like 10 minutes to disassemble it and put it back together. lol Just pull the dash panels with a torx and then, I believe its 4 small 7/32 screws, or phillips.
Thanks.
Boozebag
The wires to this control are not separate. They are in a plug that plugs directly to the fan control switch.
Another point - this looks like a non a/c
panel. IIRC, this is cable controlled with no vacuum.
Take a pic of the backside of this unit. It will be more helpful.
thats right, only cable , no vacum hoses.
and the wires are not separate theres a plug.
Boozebag
This I for an '82 to '85 S10. I'm at home, I'll look and see if I have one.
About this Discussion
3 Participants
Mad Max
S-10 Forum
Full Forum Listing
