It worked for Superman
Ok I finally went out and bought a magnetic angle finder and measured my angles but now I am not sure how to interpret them. The angle of my driveshaft at the differential is 2 degrees and the angle of my driveshaft at my tranny is 5 degrees. Right now I have 3 degree shims and no center bearing shim. If anybody can tell me with these measurements what I need to do next it would be greatly appreciated. Thanx.
Eric
I got it at Home Depot for $8. It was in the tools section with the measuring tapes.
I know some of you out there know how to do this.
NO H-body, New Dime
you need to shim up the tranny (you can use washers for that) and possibly the carrier bearing. All the degrees have to been within 2 degrees of each other to cancel out. Good luck!
How many bolts hold on the tranny and where are they located?
Old School Member
well if i were you id shim the carrier bearing... and if u crawl under your truck u cant miss it.. its right where the 2 pieces of your driveshaft meet... its got 2 bolts on it i think 15mm but its been a while so dont hold me to that
good luck
Discussion Starter · #9 ·
Oh I know about the carrier bearing. I already shimmed that. I was talking about the tranny cuz IceDime said something about shimming that too.
