2007 GMC Canyon SLE3 2.9L
Hey I live In Pigeon Forge Tennessee and I own a 2007 Gmc Canyon 4 cylinder Automatic regular cab truck and I need to if a chevy s10 pickups rear differential fit on my Truck? I know a chevy colorado fit my truck and so will certain isuzu.. I wish I could find either of those but I can't BUT I have found a chevy s10 Rear Differential so will it fit my 2007 GMC CANYON 4CYLINDER PICK UP TRUCK?? HAVE BEEN IN A HUNT FOR A REMANUFACTURED OR USED ONE BECAUSE MINE BLOW A BIG WHOLE IN IT . AND I COULDNT AFFORD A NEW REAR DIFFERENTIAL AND AXLES. SO IVE BEEN LOOKING ALL OVER FOR A REMANUFACTURED OR GOOD USED ONE THAT WILL FIT MY TRUCK. AND I FOUND THE CHEVY S10 REAR DIFFERENTIAL.
99 Blazer
You wouldn't get an S-10 rear to fit without a fair bit of fabricatioin/modification. You could find a good used one using car-part.com and searching for "axle assembly." In my area they're going for around $400-500. Make sure you get one that matches your RPO code/gear ratio.
· Premium Member
The rear axle (gear ratio) depends on several factors of a vehicle, such as 2 or 4WD, engine size, trim level, etc., and it may or may not have the locking/ limited slip differential option. The SPID sticker (in glove box) lists the RPO codes for the specific vehicle, and IIRC, the axle codes have a "G" prefix. From a quick search on Google, it appears that common axle ratios for the Canyon are, I think, as follows: GT4 -3.73, GU6 - 3.43, and GU8 - 3.08, and the L.S. option is G80. The best way to confirm your rear axle is to call the dealer, and with the VIN, they can verify how your truck is equipped. They should also be able to identify what truck models/ years the axle was used on, so that may broaden your search options.
For 4WD drivetrains, it is imperative that the front and rear axle gear ratios are exactly the same. For 2WD drivetrains, changing the rear axle gear ratio will affect drive train loading and performance, mileage, and speedometer accuracy. Your best bet, for simplicity, would be to find an exact replacement for your current axle, either used or reman.
short answer no.
colorado/isuzua/canyon are like 10 inches wider than an s10.
s10s are 5 lug, yours is 6 lug.
there is no easy way for you to go, except finding the right axle for your truck.
Thank you all so much. So what years and what models of other trucks will fit my 2007 gmc canyon regular cab truck with a 4cylinder 2.9 ??????? Please help me figure out PLEASE AND THANK YOU 😊
get off an S10 web forum, and join a colorado/canyon forum and youll get your parts and answer much much much quicker.
