ok, i know probably everybody has heard me bithc and moan about my problem with the rear of my truck sitting one inch lower on the PASSENGER side than the driver side. i got onto a flat surface and measured all four corners. it turns out the PASSENGER side front measures 1 inch higher than the driver side and is making the PASSENGER rear sit lower than the driver side of the truck. heres my measurments
driver front 27"
driver rear 28"
pass front 28
pass rear 28ish
if i can get the passenger side to come down and inch it will be sittin where i want it to be.(i dont want to put the spacer on the driver side to raise it up becuase then it will sit lower in the back than the front on both sides). should i just get part of a loop cut or what???
driver front 27"
driver rear 28"
pass front 28
pass rear 28ish
