1st Gen Crew Cab Cult
how much for 1 cross shaft with bushings and all that shipped to 85207
just in case i can get my problem fixed ill need new peices...:(
Discussion Starter #2
make it a full set of cross shafts and bushings..i just realized just one wouldnt match anyways..
ya after i took it to the machine shop and they could only help so much i called and Ricky hooked it up...
i followed the directions for the cross shaft swap so on the first side i did the bushing then the inner sleeve
then shaft with small washer, i then slid small washer on other side of shaft but had a tight fit so i used the other sleeve to push the washer down but it kinda got stuck so i tryd to compress the bushing over the sleeve and didnt work out to well...might fault
also messed up the thread on the shaft trying to make things go together with vise..
took it to a machine shop and they fixed my thread cause my tap and die set didnt go that big..and they tryd to compress the bushing but went all bad..
