I have an 02 S10 4.3 4x4 with 170k miles that will not start.
The issue started with it randomly stalling while driving, not sputtering either like I turned the key off. I pulled it home and it had no codes or security light, The fuel pump had been replaced with a cheapo so we figured that was the issue. I purchased a new fuel pump and put it in and it fired right up and then stalled after a minute. After replacing the fuel filter it had the same issue. Eventually it started only cranking and the pump wasn’t turning on. I ran power to the pump from another power source and it worked fine. So I powered the pump independently and still only cranking. I could get it to run if I kept spraying starter fluid and the coil was fine. When chasing wires I noticed that my ecm had some major corrosion around the bottom when I removed it from the bracket so after checking the harness for faults I ordered a new ecm. When I got the computer I installed it and re learned my key and it worked fine. When I went to start it again only cranking but it had the p1336 engine code for the ckp re learn. How is the relearn procedure supposed to be done without it running? Should I replace the ckp sensor?
