OK HERES THE DEAL 92 S-10 4X ,,,I KNOW YOU CAN LIFT A 4X WITH THE TORSEN BAR >>>> BUT CAN YOU LOWER IT WITH THEM AS WELL I SURE DONT WANT O SPEND 4 OR 5 HUNDRED DOLLARS ON A 4X DROP KIT SO IF ANY ONE CAN HELP IT WOULD BE A MONEY SAVER??????????????????????????????????-
Dis Member
Don't even waste your time man...
Afterhours Admin
you can loosen them the same way that you tighten them, just in reverse. turn the bolt thingy counter clockways, but count the number of turns so you do both sides the same. however, doing this will have adverse affects on the handling. when you turn them up, it gets real stiff. when you turn them down, it gets real soft..lata
Long Bed Member
another thing to do is check over on www.blazinlow.com they had a bunch of good threads on dropping 4x4's :thumbup:
well i know what has to be done now ,,,,,,,, man i wish i had a 2wd lol ,,,,,,, but hey im not made of money ,,,,,,,,,,,and if anyone else want to know how to do itgo to the site above
