is out cruisin...
well i took off my door panels today and had to disconnect my speakers that i had put down in the doors...well the next time i cranked my truck up everything was fine up, i thought....the beep noise that is supposed to go off after a lil while or when i buckle my seat belt keeps on beepin until i buckle up my seat belt....is that hows its supposed to be or did i mess up somethin unknowingly?
Better post-em.
i belive so... make sure the cheap domelight/door open pins didnt get bent... stuid things are always bendin/ breakin on me....i solved that problem real quick by just taking out that beeping box its right above the flashers under th edash. u can turn off the seat belt beeper by buckleing up or if you slide your seat forward should see 2 wires going to the seat next to the seatbelt, just cut and splice those wires together...
is out cruisin...
naw i kept that on like you said to...think it has somethin to do with the speaker not being hooked up? maybe....
is out cruisin...
haha..this is funny...i found out why it keeps beepin like it does...because i took the whole door off and didnt put it back on theres nothing touching the little pin switch so it thinks i have my door shut until i buckle up...i feel like such an idiot (hangs head in shame) sorry for the waste of your time guys and thnx for the comments
UNBANNED BITCHES!!
you mean it thinks its OPEN? :D :haha:
