They all sould be good pressure wise, but the volume(flow) is what is tricky. you need to find out how much fuel your carb or injection requires in the way of volume and size the fuel pump by this. Then you can figure out if you want a bypass(return)line system or if you want to use a pressure switch that will turn the pump on and off as pressure drops. If you are just trying to get rid of the mechanical fuel pump,maybe find a fuel tank with a fuel pump in a bone yard? It will probably be sized for your needs if you don't get radical w/engine mods and it will be set up for a fuel return already. WHOLE LOT LESS WORK.
