i have a 86 s10 I love it 4x4 metallic black or grey anyway I installed a cd player a while back and never hooked up the 12 volt memory wire can any body help me as to how I hook a wire to the battery and how I should do it I am getting tired of my cd player resetting
LEAD FOOT LARRY
In your fuse box you find where the radio memory wire goes and connect there.
If you have a meter, find a point that has 12 volts with the key off.
The alternative is under the hood, on the fire wall, between the dist and AC is a terminal block. There will be many red wires connected there. It is 12 volts constant.
Look at the fuse block. At the top there are some terminals labled BAT. Use one of those.
