Well that is not the best way, a regular open diff will sometimes spin both tires, and on the inverse the stock lsd will spin 1 tire sometimes. To be sure, open the glove box and on the door check the rpo codes, look for G80 for posi and the other G code will tell you what ratio you have, I know gt4 is 4.10's and I think GU8 is 3.73's. The rearend is a 7.5/7.625 just like in 3rd and 4th gen f body's, with a 2.2 I would be willing to bet you either have 3.73's or 4.10's. You're not going to want a spool for the street, the axles will not last long on the street considering when you make turns both wheels will continue to spin at the same speed. Also, I don't see the point of a spool on a 2.2, the stock setup is more than adequate for what the 2.2 can throw at it, maybe if you ever get up into the 300+ rwhp range you would need to upgrade things, but I don't see that happening. If anything at all, just get a zexel torsen posi unit for $99 and throw that in there if you don't have posi already (probably don't) and that will be great.
