Gaaoooooo
Daveman2 said:
Yeah how do I seperate the pulley from the power steering pump? It's got a little hole for a fat hex wrench but I dont know how to hold it in place
You need a special "puller", I got one from autozone for $15 and kept it, it has a 2 piece circle that you put around the groove in the pulley, then a thin piece of metal that holds it together, then you just tighten down on the nut as the pin pushes on the pump shaft itself. You have to use this tool to reinstall as well.
Function Over Form
Yup just like ^ said, you need a pulley puller.
