1 - 20 of 125 Posts
1996 2.2l auto reg.cab DD
Here it is! It will be done on my 1996 s10 2.2l reg. cab short box 4x2 with 153k. I know it needed it so needless to say I did it lol I know this isn't a how to but it shows what you will be facing. I did run into some snages but I had my dad there to help me out the whole way. I know every one needs/wants to do it but wants to see pics and A LOT of them so I took a good amount to show some things. Hope you like it!
The parts I used
  • timing chain
  • timing sprockets (2)
  • chain tensioner
  • shaft seal
  • cover gasket
  • sylicone (blue stuff)
all of it was bought from Napa for about $115 out the door.(everything) so on with the pics since I know that's why you are looking at this! lol
My ride, feel free to compliment a 11 year old stock DD. I made that push bar and I'm making a new big warn bumper(a big one) this year in shop class at Blaine High
Remember daily driver lol
Start by undoing the air filter housing hose that goes to the shroud with a flat head. basic lol
Don't forget to unclip the sensor on the bottom of this hose.
Yet again, undo this one as well but no sensors
Then you have somthing like this. I went mudding 6 months ago and I really wish I wouldn't have. I did go through more mud than my buddie's 2001 blazer with 4x4 and I was balls deep. Good thing for my good tires that I suggest getting if you are DD looking for some new rubber Firestone Discoveries A/T
Unscrew these four screws to remove the fan shroud
Getting there. You should be looking like this. Hopefully cleaner though lol
Unclip the over flow hose for the coolant. Don't damage clips
To unsecure the bottom of the fan shroud, use a flat head to push between the tab and the fan shrould wall to release the push-in clip(from the top side of engine bay). Its undone here already to show you what it looks like. (middle of pic) Then it should be loose and then take it up around the fan
Looking good, pretty easy ehh?
Just loosen these four nuts around the fan clutch/pulley. ONLY LOOSEN, KEEP BELT ON TELL I TELL YOU TO TAKE IT OFF!
Now you can *loosen* the water pump pully bolts (on right side middle) then you can take off the belt.
Behind fan pulley
Take off the water pump pulley. I just replaced mine last week, so if you ever need to replace it this is how you get at it.
Take the serpentine belt tensioner off with these three* bolts sorry for the shacky hands lol.
Don't forget to take this lil guy out. Its the oil filter drain pan screw.
You should be here by now.
Now for this guy, this would be the cover for your *timing chain*. For the big pulley, use a screw driver to wedge up against the bottom right corner of the cover that has a 90 angle and unscrew the bolts. I did the out side three then the middle one.
You should be looking at somthing like this
Then you need some kind off puller like this. You pull the thing out and its actually on the end of this puller. The puller threads into the outer three bolt holes then you twist and ta da its out. It's takes a while to get it out, cramps are common! Take a breather and have a pop or beverage of choice.
So now you can see the round seal or shaft seal that you will be replacing. If you have to run to the auto store you can buy a seal puller or just use a good old srew driver and a hammer(like me).
Take out all bolts holding the front cover on.
DON'T FORGET THESE NUTS! They are at the bottom of both corners of the cover underneath.(sry about the sec. pic. the nut is 2/3 to the right and 1/2 way down behind the line runing left to right in pic. for the bottom pic above)
To take to cover off...pull it free of the seal. Make both studs on the bottom corners loose..then pull them up evenly or the right then the left side. What I did was pulled the right side up then pulled the cover really hard towards the alternator then out towards the front bumper..it should pop right out. It took me about 30min to get it but I didnt have a clue of how to go about the best way so thats how I did it. Basically just get the pain in the a$$ out of there. I had to undo the two bolts on the right of the alternator. The one on the back and the one in the front. (both the right ones all the way out) then loosen* the left front one to just swing it out of the way.
Just a pic of what it looks like if you want to know. I knew every one wants to just see it so here you go guys look at it like the new mag. in the mail jk
Now pull the big sprocket of with "two large flat head srew drivers" as the chiliton manual says
Some pics of the orifice, every one wants to replace but no one can find. Sorry again for the shaking hands
http://viewmorepics.myspace.com/ind...itAlbumPhoto&albumID=2274031&imageID=44924978
Take off the chain tensioner and use a pulley puller to remove the smaller sprocket. Then before moving on, push some towels into the oil pan opening to make sure nothing big gets in there or hopfully nothing at all if possible :)
If you ever see a truck like this always backed up in a garage every weekend in Blaine Mn its most likly me lol jk but its always in there, not because anything broke but because I work to get money and I spend it on my pride and joy lol my anti drug if you want to say:rotf:
Where you should be.
Time to clean the cover off with gas and a metal or hard like brush then clean and rinse with dawn dish soap or what every you prefer. By the way this is my inspiration to life, my dad. look at the trooper just clean that baby right up!
http://viewmorepics.myspace.com/ind...itAlbumPhoto&albumID=2274031&imageID=44925024
So now you have to clean all the old silicone off and all the places where you see build up that need to be cleaned. I used my finger nails alot but I used a utility knife to get the big stuff, just watch you oil pan so nothing drops in there. re-assemble and enjoy your new timing parts!
Here is some pics of the wear on my old tensioner.
the groved or unlevel spots are where the chain wore it down.
http://viewmorepics.myspace.com/ind...itAlbumPhoto&albumID=2274031&imageID=44924992
My dad said it was definitely worn but not to the point of desperate need of attention. He did say its better to change it now then when you are rushed and have to change it out of the blue.
I bleed for my truck. I was pulling a pry bar out and I couldint get it so my dad says "What, you can't pull it out?", So I pulled really hard, the bar gave then hit the power steering/frame, slide between my palm and then my thumb first into the frame and it was a gusher lol it hurt like hell:eek:! I was half way done and it suck when my blood pressure raised and it would throb, have sharp pains but it was worth it!
Im glad that I did it and I hope this has been helpful to all that have viewed this. Feel free to help others with questions about anything related. I will try to keep up, but I'm maxed out at work and I'm in high school so you know where I'm at. If I'm not caught up on here, so help each other when I'm not around please lol. Comments for the first person (me) to show how to do this would be very nice lol jk if you want. and you are welcome.
Currently Spoolin
Tech Mod
Awesome writeup :tup:
Discussion Starter · #9 ·
the altinator just had to sweep to the left like a hing on the front left mount bolt. you have to take both the right mount bolts off. one on the back side and one on the front. then it can slide out of the way. but just back the left bolt out about 3 turns or just enough so it can slide/rock on the 1 remaining bolt.
Discussion Starter · #12 ·
why not? i thought the same when i knew i should. Im not that great at working on it but i get by. Its painless, the hardest thing is to take to cover off then putting it back on. do it EXACTLY as i explaned it other wise it will not go in. I was trying for an hour just to get it out then 2 to get it back in. i was pissed and i was just laughting at how pathetic it was just because i couldint get it to move 1/8" more for the bottom right stud to get homed so i was joking and i said and did this while i was saying it to my dad which was histarical with me-
" first you do this, then do that then push like *%$#@ &%^$# (you get the point) and then it's in, and it did go in!!!
my dad said "unbelievable, now take it out and do it again
he said that because we striped all the new glue off and the gausket because we couldint get the cover in and the cylicone was drying so i was just pissed and joking around with it just about to walk away for awhile
Oasis Customs
looks good, now i dont feel to bad about having to eventualy do this. where did you get all the parts?
Edit: i saw napa when i looked again lol.
Discussion Starter · #16 ·
thanks! i didnt think it was going to be a big hit or not i just thought i would take a few just to show people how easy it was. if it could be made a sticky i think it would help alot of people see it and let them know how? if every one thinks it would make a good sticky that is lol its up to the modds or who ever
1 - 20 of 125 Posts
