anybody know how to install a tach on a 2000 s10 5 speed? its by autometer. i really just need to know where to hook up the wire that gets the RPM's i know how to hook all the other wires up. thanks
i splice the signal wire at the PCM..i belive it is a white wire...yeah ...it is a white wire...PIN 10 on the on the #2 Connector which should be black..i used this method and it has worked great for over a year..
Hope this helps.
Kenny
The best way to find out is to go to www.autometer.com and get the number and call them. They will be able to tell you exactly where to connect it.:thumbup:
is the P.C.M located closely to under the ashtray? if it is tehn my has 3 blue connectors (which is confusing me), so i looked at the middle one and there is no wire going into the 10th hole.but there is a white one going into the 11th hole. and i tried the green wire on top of my instrument cluster harness and it did no good. what to do?
