Ok I told you guys I would get this HOw to up sometime soon. Here it is.
The First step is to take your old headliner out of the truck, this is for the ext cab, not sure about the regular cab. It involves 3 screws around each sunvisor mount. 1 in each part the sunvisor gets held into. there are 2 small bolts on the grab handle over the passenger side door. 1 screw in the coat hanger clip thing on the ext cab, and 1 screw on the passenger side in the flip out latch by the ceiling. The last part u need to remove is the light housing on the back wall. It has 2 samll bolts holding it there.
Once u have the headliner out you need to remove the cloth that is currently on it. Just start at a corner and slowly work your way around the whole thing until it all comes free.
Next you need to cut out of 1/2" foam whatever design it is that you want to be on your headliner. For mine i chose a bowtie with flames coming off of it.
Next you need to center where your gonna put your design at. I chose the middle of my headliner so the next thing to do was spray the foam and headliner area where u are going to attach it with 3m adhesive spray and let it sit for about 2 minutes, or until it gets tacky.
Ok now that the foam is securely in place you can start to cover the headliner with your material of choosing, I chose to use just regular headliner material i got at a local fabric store, but anyway start by putting more adhesive on both the material and the headliner itself and let it sit for 2 minutes. Only work with small areas at a time, or u will get it all messed up. Make sure u push really hard on the areas surrounding your design, so it will attach, this may require you to press on it for a few seconds to get it to hold, but once u get it held on, it wont come off.
Now that all of that is done, it is time to take a pair of good sharp scissors and cut off all of the excess material around the edges, take your time and dont **** up, or it will show.
Now that is it all that is left to do is reinstall the headliner and enjoy your creation. Not that hard to do, and should only take you half a day or so to complete.
One more note, if you get any of the glue on the good side of the headliner, dont fret, use 3m adhesive remover and it will come right off, this also works extremely well if you get it on your hands, it takes it off great
