1 - 20 of 61 Posts
I am going to do a true dual setup on my 4.3.
I am going from the headers back. My question is how to do it...
1.Do i run two pipes in and out of a xpipe then into two separate mufflers.
2.Do I run two pipes into two mufflers independently....
3.Do I run a dual in and dual out muffler...
Whats your guys suggestion?
When we did duals on my buddies tahoe we rand two separate pipes into two mufflers, no x pipe.
New Old Timer
Two singles are old school duals. They are a good improvement over stock single systems, but not as good as a dual w/ X-pipe. The X-pipe system creates the best of both torque and horsepower. Look under almost all winning NASCAR Sprint Cup Cars and you will see an X-Pipe exhaust system. You just need to use the proper size for your anticipated (be realistic here!) horsepower. For tips on sizing, see here: http://www.exhaustvideos.com/faq/how-to-calculate-muffler-size-pipe-diameter/
Premium Member
I would go with dials with an x pipe as well. I would put two stainless magnaflow single in single out mufflers on similar to the one I have on now. Our camaro has true duals with an x pipe and 2 single in single out dynomax mufflers.
I wouldn't personally go with those mufflers though becuase the magnaflow are built a lot better, are stainless and are deep but do not have the drone you would get from say a flowmaster muffler on the highway.
We'll we are building a header back setup, aka fabing up a new y pipe cause no one makes a decent one I've found. So to run duals, vs a single in dual out... its basicly the same work.
Was planning on running 2" all the way back
Going from a single 1.5" pipe to dual 2" pipes is about 3.5-4 x increase in area. Can your engine support such a large increase in flow, without having exhaust gas velocities drop to much? I have a hard time believing even a mild 4.3L needs that much extra flow.
Gaaoooooo
Kind of a waste if you ask me, the gas tank is in the way so you have to run the left side pipe over to the right side anyways...might as well just make a nice 2.25" y pipe and either a single 3" or split it at the muffler for dual tailpipes.
Gaaoooooo
This is an s10 not a 1973 Super Beetle, stock exhaust size is 2.5" into stock muffler/2.25" tailpipe.
Discussion Starter · #11 ·
I am going to run both pipes down the passenger side and have them exit before the right rear tire. I figured it would take the same amount of time to run both pipes and it would be to make the y pipe.
I thought 2" pipe would be the correct size pipe. I plan on supercharging the truck in the spring. hoping to see 300ish hp out of it. Thats about as extreme as I plan on getting.
New Old Timer
A dual 2" system would be slightly small for a S/Ced 4.3L. A dual 2" system is good to about 289 hp, assuming all the piping is straight and the muffler is a straight through design. Being S/Ced going slightly larger wouldn't hurt performance nearly as much as a naturally aspirated (N/A) motor. A dual 2 1/4" system is good to 371 hp N/A and the parts are much easier to find. For example, Summit Racing has plenty of parts in 2 1/4" (including a narrow angle X-Pipe: http://www.summitracing.com/parts/SUM-643122/ , handy for running duals down one side).
Gaaoooooo
I don't feel 2" exhaust is worth it ever, maybe if you're working on a sub 2.0 liter engine, 2" will sound funny too. If you're going to run the dual pipes you might as well use 2.25" or 2.5", if you are running a muffler and/or a cat also there will be plenty of backpressure, a crossover pipe (I like x pipes) to me is mandatory.
Bold as Love
2" true duals on a 4.3 would pop and cackle like hell more than likely.
Although I've considered doing it with a set of Porter or Smithy's steel pack mufflers just to see what it sounded like.
New Old Timer
Where should the x pipe be placed? Close to the headers?.
Just ordered a 2.5" x pipe, and two 2.5" flowmaster 44's.
As far forward (close to the headers/collectors) as you reasonably can. (I take it you are doing a V8 swap, using 2.5" pipes?)
StirFrey, while H-pipes do help balance the pressure differential, they aren't as effective at balancing pressure and scavenging the exhaust pulses as an X-pipe.
Wondersmith
but with something like a 4.3 wouldnt it be better suited to an h-pipe, i was always under the impression that an x pipe would work better/have better results with a higher end engine... you know a v8 or something with actual power?
or am i backwards?
Gaaoooooo
or am i backwards?
I don't think this is true, I have a blistering 225hp 5.0 with a x pipe, lots of people use h pipes on the same engine...it mostly comes down to sound preference.
1 - 20 of 61 Posts
