well with my 5-5 drop my frame is still like 1.5" from the ground and i cant get an alignment so im thinging im going to bag the back how do you do this on a blazer i am only familiar with over the axel setups which i cant do here
Afterhours Admin
You dropped it 5/5, and its 1.5" off the ground, and thats bad? If you drop it any further you wont be able to drive the damn thing..Whats alignment got to do with the back?
Anyway, the blazers suck ass, and the only way Ive found to be somewhat simple is to mount sleeve bags in front of the axle. The blazer I did like this rode friggin great, and its about the only option besides air over leaf or airshocks if you dont wanna notch the frame or cut thru the floor. Heres some pics of what I did:
http://www.s10forum.com/forum/attachment.php?s=&postid=490056
http://www.s10forum.com/forum/attachment.php?s=&postid=492696
http://www.s10forum.com/forum/attachment.php?s=&postid=492698
This is the truck, the axle hits the frame in the back, and hes got giant 29.75" tires on it. I dunno what size tires youre running, but a 24.5" tire (something that clears the wheel well) will prolly make this truck damn near lay out. No drop spindles ont his either:
Up: http://www.s10forum.com/forum/attachment.php?s=&postid=492705
Down: http://www.s10forum.com/forum/attachment.php?s=&postid=492708
THE FRAME DIPS IN THE BACK SO ITS WAY LOW AND WONT GO ON AN ALIGNMENT RACK OR PIT I ALREADY C NOTCHED THE FRAME AND I HAVE 205-65-15 UP FRONT AND 235 60 15 IN REAR SHOULD I MOVE THE 235'S UP FRONT AND GET A BIGGER REAR TIRE? AND WILL THE AIR SHOCKS BOLT UP EVEN IF ITS DROPED OR DO THEY MAKE A LOWERED AIR SHOCK I ALSO WANT TO TOW WITH THE TRUCK SO I NEED TO GET THE BACK UP WHEN I TOW
Afterhours Admin
Uhh..I dunno what airshocks are rated at, so I dunno if they will stand towing. Ya theyll bolt up when its dropped, stock blazer shocks are long as hell.
