81 - 83 of 83 Posts
Best thing to do is right below the hinge, look for a spot on the door that is a single sheet of metal and drill a hole out, put a grommet in to keep your wires from getting cut on any rough edges or shavings and then run your wires through. If you want to get it water proofed you can go down to a junk yard and look for a similar truck with power windows/locks and take the rubber boot from them and just install it on your truck.
81 - 83 of 83 Posts
