It wasn't an insult...fb...Facebook.You're not going to explain the boomer FB insult to me?
I think the trick is to remember that every truck will be different. You need to get super familiar with the wiring diagrams for your specific truck, and the specific motor you're dropping in it.Would something like this: https://lt1swap.com/gmt400swap/index.htm be what I need? Since the truck is a 2.2 bellhousings are different on the 4L60E so I plan on using the 4L80E, it seems he only mentions the 4.3 so just wanted to make sure that it's not too different wire wise.
The advantage you had was being a 40 GM tech. That wasn't ask option for us, even though Harley is a wiring King. This swap was going on right at the height of covid, and we needed to get this wrapped up.By the time I finished my harness, besides having both FSM's, I had close to 50 pages of specific section diagrams I downloaded. W/o them it'd be tough to get it all right. mine was just the opposite. I kept the A/C, cruise, DBW, evap, TBSI, Vats, etc. And upgraded the PCM to an 04 P59.
I think if I were to do it again I'd first swap the truck to an 01-02 0411 while the 4.3 was still in it. Get all the bugs worked out of that. Then add what was needed for the LS coils, injectors, and DBW.
P59 ECM...CPW did tell us that the ABS wouldn't work, so we replaced the bread box sized ABS with one from a 2000, along with a M/C and 8" brake booster. The smaller booster was needed to clear the fuel rail covers. ABS works fine, as does all of the gauges.Depends on what you're running. If you have changed the trans or A/C style you have to have a custom one made. IIRC in Rhot's case they were using a later computer in a 96.
I've also been led to believe if you have 4wd you have to wire that stuff yourself since they won't include any transfer case or TCCM wiring.
My harness included a 4x4 two wire connector. It was up by the 16 pin connector that is close to the evaporator box/PCM. I have no clue what it is for. This leads me to believe CPW makes a standard S10 style swap harness and adds in what specific changes are requested by the customer. Mine also had a flex fuel connector and I never spoke of using the flex fuel sensor. I have that tucked over by the brake booster under the cruise/pedal sensor.Depends on what you're running. If you have changed the trans or A/C style you have to have a custom one made. IIRC in Rhot's case they were using a later computer in a 96.
Word of caution demonizing a specific Mfg. Be sure your legal advisor says you have evidence to win possible suit that could result. Wouldn't be pleasant to face the same problem that several now do in demonizing Vote Machine Manufacturers.Don't use the Cpw piece of s***t harness and save yourself $1000.00 plus. If you decide to waste your money DONT USE JOE .He has no idea what he is doing.
