1 - 12 of 12 Posts
s-calade said:
i have stock rims with 255/75/15 tires on them. if i decide to go with 215/45/15, how much would the truck lower? same question with 215/55/15.
thanks
i wouldn't go with a tire that small.
i would go with a 215/60/15 in the front, and a 255/60/15 in the rear.
or if you want a little bit smaller, 215/55 and 255/55
here is a pic of my old truck with 215/60 and 255/60 on a 5/6 drop.
i had 215/50 all the way around, let me see if i can find a picture, but they look way to small.
ok, this is 215/50/15 on a 5/4 drop
you cant really see the wheel gap in this picture
and this is what that size tire looks like on a lifted truck :D
needs a new project
Discussion Starter #8
i went with the size 50 tire. and ended up with a 5/4 drop to get me level. my frame is about 3.5 inches from the ground. looks good. ill get pictures up when i get time. probably beginning of next week.
BARELY Tuckin' Tire
since you guys didn't go with a bigger rim, yet went with smaller profile tires...did that throw off your speedometer?? i believe it should have....
BARELY Tuckin' Tire
yeah i just did it...when going from a 205ish/70/15 tire to a 215ish/50/15 you're running 10.8% too fast...just something to consider...although better to have your speedo run too fast then too slow.
s-calade said:
yah i did throw it off a little i think. i cant figure out how much though. yah it is better too fast than too slow
your speedo is about 10mph to fast
and even if you get a HPPIII it wont correct it, you have like a 24inch tire, and the smallest the programmer goes it is a 25.
but still get one, because the miles go up pretty fast when its 10mph to fast.
1 - 12 of 12 Posts
