I have a 99 S-10 that quite running. It was running fine as I was driving down the road and it just died, it sounded like those car that keep running when you shut them off. I pulled it home, checked the spark, that was fine. I changed the fuel filter cuz I happened to have one and I noticed real fine glitter in the gas that came out of the line by the filter. I could hear the pump wine but still suspected the fuel pump. I bought a fuel pressure gauge and I have 55 psi at the engine, the manual says I should have 60-66 psi. Is 55 too low for it to run? I have to make sure it's the fuel pump before I change it cuz a new one is $400, and more if I go with a AC Delco. Jake
