1 - 14 of 14 Posts
hi,
i'm wondering how many litres or gallons in my gas tank?(sonoma 97 2.2l x-cab)
my fuel gage does not work,
it reads always full, any idea what's the problem , fuel sender unit ?
Hello there!
Owners manual says 19 gallons but I can't fill it any higher then 16 gallons. It's probably the fuel sender unit that has gone out or it has gotten hung up. The fuel sender unit come with a fuel pump in an assembly and are 300 dollars.
child at heart
my 98 has a 19 gal tank and it will hold every bit of too. almost found out the hard way once when it sputtered into a gas station, 18.9 gal later it was filled to the very top of the neck.
im not sure... whatever mine is it aint that big anymore... its got a huugge fvcking dent in it
Super Moderator
I was on the E line and filld it up wit 14.7gal, the fuel lines can hold total of a gal so tht gits ya another 20-35miles dependn on yer miles per gallon average
good to know. probably not the best on your fuel pump. infact i know its not good on your fuel pump. lol but just incase i guess.
i just filled up and it took 16.7 but i kept filling after it 'clicked' or stopped pumping.
so im a 16 gallon tank too.
i figured out that each line on the fuel level is a gallon. next time the needle is at like a the 3rd line see how many gallons u put in and see how many lines it goes up.
an my guage stopped working too. once i get less than a half tank it doesnt work, it says i have 3/4 of a tank
xtrememeasures10 said:
Mine will only hold about 13 for some reason. 97 2.2L 5spd 2X4. Anyone know if its suppose to be 13?
lol... you have a dent in your tank like me? :rotf:
Completly Useless Truck
my tank will hold 18 if i get really low, but then have never run out either...
usually i never let it get that low... And no dents...
1 - 14 of 14 Posts
