Draggin Body Member...
I need help real quick, I'm trying to get stuff done today and I cant get the focking upper control arm on the passenger side off, so what in the worlf do I need to do to get it off????? its hitting on the steering column.. Do the bolts holding it on come out??
Cannabis Guru
yes the bolts come out they are just in there tight
id just take the lower off
because the upper has shims and ull throw the alignment off and all that stuff if u dont put the right shims in the rights place
Afterhours Admin
moved to traditional..
First off the steering column is on the drivers side, so your passenger side arm shouldnt have any problems with it. Ya the bolts come out of the frame but they are pressed in so youll need to get them out, usually a c-clamp or pry bar or something can get them out. Typically the rear bolt is the one holding the arm up, if you take that out then the arm should come off.
