Status
Not open for further replies.
21 - 40 of 44 Posts
Diesels10, this is a great writeup!! the info on the 4l60 is a big help. I have been thinking about a 241/241 doubler for my 85 jimmy for the past week while i have been sitting in class at college. Your build is phenominal. I have to say that i think your project has been the most informative of any other s10 4x4 build i have ever followed. This brings a huge smile to my face every time a show my roomate (a jeep guy) some of the crazy stuff you have going on. I donno if you have ever looked on a jeep forum but it seems like those guys have tons of stuff figured out for their rigs. I have been trying to find at least a couple people that have things figured out with s10's and it has kinda been a struggle. So all in all thanks for posting and keeping the s10 guys competitive. i have been reading up on your build and its funny because I have been tossing around a lot of the ideas you have done. But mine are on a little smaller scale haha. for example, you extended your truck. I made my jimmy into the smallest pickup ever. i have been thinking of doing a diesel swap but with a cummins 4bt. i have been collecting parts to do a sas with a 3 link up front. after i graduate from college this spring i am diving into my build so i will probably have some questions. Anyway thanks again for posting some great info!!
· Spark Plugs Are Overrated
Discussion Starter · #23 ·
you ever get that vid of you in double low?
I'm always in double low. :D
But no, I never did. I'll get one when I get it back to life, besides it will be about 20:1 lower with the Allison's 3.10:1 first gear vs. the 2.48:1 in the 4L80E.
Discussion Starter · #24 ·
Thanks for the compliments and I'm glad that you are able to something out of my rambling, that's why I took the time to do it. I don't have much to do with Jeeps, the wheel base is just to short for my liking, besides all of the "good" Jeeps are stocked full of Chevy parts with extended wheelbases and even then you still have a weak frame when compared to the S10. I believe most people choose Jeeps because that's what they see and most people can't get(think) past what they see.
I don't know if you have seen this link yet, but a friend of mine has built a truck very similar to what your wanting. Here is a link to it: http://www.s10forum.com/forum/f221/a-buddies-96-a-424692/
· Southern Dime
Can you disengage to rear drive to do front diggs?with the doubler
Discussion Starter · #27 · (Edited)
I can finally add a little more to this thread.
I had to rebuild the shaft that goes between the cases to add a little "beef" for my new power plant, so I can better show how I did it without having the equipment to spline shafts. This is basically the same way that I made it the last time, but last time it had a 27 spline ouput instaed of the 32 spline. I just removed the 27 spline portion of it before these pice were taken.
This is the factory main shaft that runs from the planetary to the tail housing where your rear driveshaft yoke slides on, but I have cut it off just behind where it exits the planetary. The left side is what is towards the front of the vehicle and the large side is where I cut it off, the hole through it is factory.
From here I just needed to locate a 32 spline shaft that was long enough, then I cut it off to the length that I needed it to be. With the thickness that I made the adapter the shaft needed to be 8 3/16" overall.
At this point it was time to turn the front side of the 32 spline section down until it slides into the hole in the other section, but it must fit very tightly as this is what centers the two sections.
This is what it looked like after turning it down.
Now you just press one into the other.
At this point I placed the shaft back in the lathe and inserted the centering pin in the other side of it and spun it to make sure that it is straight and true.
Here is were it gets a little tricky. It has to be welded very good, but it can't warp, so pay attention.
And the finished product.
Now I can't say exactly how strong this method is, but I think I'm getting ready to find out as the Duramax feeding this shaft will be tuned to around 1000 ft/lb of torque. With the 27 spline version of this shaft, which was built the same way, I towed a gooseneck trailer that was loaded to 12,500 lbs and was it was powered by a turbo diesel that was putting out right at 400 ft/lbs, so this method seems to be fairy strong.
Hope this helps.
Discussion Starter · #29 ·
EDIT:
It was brought to my attention by a member on another forum that the center hole in the main shaft that is modified as mentioned above isn't always perfectly centered, so be sure to check it before you use it as a centering point as I did.
It's funny how this stuff works... I just came up with a brilliant idea a few days ago. Looking at various 241 cases I have around wanting to replace the 236 in my 99 blazer I thought, "wouldn't it be awesome to have a 242/241?" SO... I had to get o line and search. You know, see if it was do-able.
Uhhhh, double-able??? Anyway...
Funny how posts like this showed up as well as places like ORD putting out kits for 241 based doubles right about now! My brain is always ten steps ahead but always behind.
(Ahead of local folks but usually find online my idea fleshed out... Just how I like it, no new ground to break!)
How is that shaft holding up? Less than three hours away in AR, how much or what would trade value be too ya to duplicate the setup for me? I'll still have one DD and one PD 241 case... Want to rip apart a Tahoe I have and run it for a trail rig. Toss up between it and a 5.9 Limited ZJ sitting next to it... I need to drop a few projects and get the rest useable!
P.S. before anyone calls me on the old thread, duhhh! I don't spend much time talking... Reading usually but when I want to pull up an old thread after searching, well, old thread or new thread about old topic, I'd rather lost on the old. Otherwise I'd waste someone's time directing me to the old thread I already read!
Discussion Starter · #31 ·
Welcome aboard Wildcat and FWIW I just copied the idea from another guy on here with a Box For Rocks doubler kit, I'm just to cheap to pay for stuff, lol. And as far as digging up an old thread goes, it's a sticky and always at the top, so your good!
I will actually be building another complete doubler setup for a spare to take on a trip to Moab in a couple of years and one for a buddy, so one may be able to persuade me into doing more while I'm doing it/them.
About it holding up, yes it's been a few years, but I only drove it for a year and a half before I put it back under the knife for a new engine, but in that time I drove it around 7,500 miles. I drove it daily, played in the rocks briefly and towed loads with a total load of 18,200 lbs counting the truck itself and pushed it while loaded (held on the floor until 65 mph running uphill) and it held fine and was only 27 spline input into the second case at the time. I have since upgraded it to a 32 spline into the second case to deal with the new engiine output, but with a welded shaft just like the first. I have a friend that can turn the shaft from scratch that I will be talking with next week about prices. I'm sure we can work something out if time permits.
Nice... Oh, I'm not really new... Long time lurker and been a member over two years... I always recognize your truck from posts here and there online.
I haven't messed with a S series in a looong time. This one has been sitting around like all the other projects I never have time for.
If I could SAS this Tahoe it might save the Blazer for a DD which will keep the wife happy for awhile. I think I'm going to sell the Jeep though it would be a decent trail rig too, but I don't need so many...
To start I guess I could put my Burban front axle under the Tahoe and run the PD case Behind a cut DD case. Then I could just go bigger on axles when I bash the thing up enough to start really wheeling it.
As for the rant, so many of these places (mostly pirate), people just LOVE to raise their post count to prove that they are superior by scolding people for everything. Same folks have no issues telling you how old the thread is one second, then the next they are complaining that someone didnt use the search! LOL!
Discussion Starter · #33 ·
This is definately not Pirate and hopefully it stays that way. Everyone likes to talk about all of the tech on that site, but you've got to read through 12 pages of immature whining to get to any of it.
Speaking of reading, I spent a bit reading about a Dmax swap... Is it road worthy? And what's this about a smoke wagon in a 70 Caddy? Are you nuts? LOL! I'd like to have a 500+ cube caddy in my Tahoe with tons under it...That, EFI, 4L80E, double 241's should be plenty for me. I don't like the idea of all the weight of a diesel in something unless it is needed.
How much does your Dmax weigh? Id love to see a "S" truck pulling a large trailer passing dodge trucks on the highway! The looks on their faces would be priceless!
Back to the TC business, sign me up! I'd like a good excuse to see a Dmax10! What you charging for rides?
Discussion Starter · #35 ·
Sorry it took so long to reply, I missed your post somehow...
It isn't road worthy yet, but it's getting REALLY close.
A Duramax would be a hoot in the old Deville, but it would be really hard for me to pull a 472/500 out of anything, lol.
I hear you on the weight of the diesel too, but I will gladly trade the extra weight for double the effiency AND power, lol.
I'm not positive about the weight yet, but I'm expecting right around 6,000 to 6,100lbs, it's FAT for an S10. It weighed 5,760 with the Detroit/4
l80e setup.
And rides are free, just come by when I get this ugly turd road worthy!
Hey Diesel. I joined this forum just to make this post and ask you a few questions. I checked out your build too, by the way - its pretty amazing what you've done. Anway, I think I'm in the same boat as WildcatKit52, where I was in the basement looking at my spare 241 that had a bad output bearing and pump and was thinking to myself that the front planetaries are still in good condition. I did some quick research and figured out that someone makes a 231 doubler setup, so I figured why not see if I can rig something together. I made a post on Pirate and they led me to here.
Anyway, I know you mentioned something about making more doublers for your Moab trip and was curious about a couple things.
First - the part where you welded the shaved down 6-hole t-case adapter plate to the larger flat plate, what was stopping you from simply drilling those 6 holes into the larger flat plate?
Second - I read somewhere that someone broke their adapter shaft on their D&D 231 doubler and the company made them a new one for $75 (versus the $225 you mentioned). I wonder if the 231 splines coming out of the planetary setup are the same as the 241 (since I know a lot of them are). Might be easier for some of us without access to a lathe and welder in the same location (I have access to a lathe but no welder at work, but my welder is at home).
Third - how many passes did you do on the intermediate shaft? It looks like two to me, but it also looks like you could have done a couple more, if nothing more than to increase the OD of the weld area and significantly increase the torque rating (even though I know you said it held up to 400 lb-ft and lots of weight - just curious).
Fourth - how much would you say you've beat on in it double-low? I ask because if you've got the front case in low, it's multiplying the torque by 2.72 onto the intermediate shaft. Obviously if you're in single low, you'd want to use the rear-most case to limit the torque on the intermediate shaft, but have you done any tough stuff with the front case half in low? I only ask because this is going in a 6000+ lb truck and I want to make sure I don't leave myself stranded somewhere if the intermediate shaft breaks. Though I guess I could always make a spare one to bring along with me, just in case.
I'm really excited to get this project going. I have a 2001 Silverado half ton with a Dana 60 up front and 14b 10.5" out back that I really need to run a new rear drive shaft on, so I figure now would be the time to add the doubler into the mix. Plus my front drive shaft is super unbalanced and I've been wanting to re-tube it, so now would also be a good time for that. Plus the angle is about as steep as I'd ever want it to be so lessening the angle is also a good thing. I just don't see any downsides to doing this other than cost.
And I appreciate any advice you can give on this!
Discussion Starter · #37 ·
The reason that I did this was because the transfer case indexes into that adapter and I my little lathe can't turn a piece as large as the adapter plate. Obviously I'm to cheap to pay someone to turn it for me, lol, so I just decided to use what was originally indexing it because it was there.
The $225 was a guesstimate based on what a freind that has been in the business for years sells his for, $75 is cheap IMO, but it didn't hold up so it must not have been to much of a bargain. I would assume that the splines between the 231 and 241 would be the same because I believe I read that the planetaries will swap between them, but I am not sure. Again, I just did it this way because I could do it myself without paying to have it done.
On the first one I believe it was two passes and that's the one I ran it with behind the 6.5 that was making around 400 ft/lbs of trq and was using a 27 spline input gear on the second case. I rebuilt the shaft for the current setup for a 32 spline input on the second case since I more than doubled the torque input with the tuned Duramax, not to mention the lower gearing in the Allison, and I made a third pass on it tapering it from the larger portion to the 32 spline section. This engine should be putting out somewhere around 825-850 ft/lbs as it is right now and pulling a 24' bumper pull trailer with it with a moderate load of steel it will break the tires loose up to around 35 mph on dry pavement and the shaft is taking it fine. I had it out last month due to a rear transfer case failure (that I caused from a missing C-clip) at it looked great with no signs of stress. A good friend of mine that used to build a lot of axle shafts and stub shafts said that this welded shaft is probably stronger than one I could buy.
I haven't been able to beat on it much at all in double low as I really haven't had it ready to wheel much until recently and now I'm having an issue with the Allison, so I can't comment much here. I will always run the rear case in low before I engage the front case though for the reason you mentioned above. There is no reason to run the front one in low before the rear. My truck hovers just below 6K also, so we will be playing with the same fire from a weight stanpoint. This setup would most definitely be vulnerable to breakage, but I'm more worried about damaging it from contact with rocks than internally mainly because of my wheeling style. I'm very patient and practice good right foot control, seldom ever throttling it. The shear beauty of this setup is the cost IMO, if I did grenade the entire setup I have very little in it and a pile of 241's under the bench in the shop and the adapter plate is reusable. Cutting the side off and having the section of aluminum to fill the gap on the front case is all that would have to be done to have another one ready to go other than the intermediate shaft. Weight is another perk, my 203/241 doubler weighed a ton compared to this one. I have installed this entire setup in my truck, without using the lift or a jack, by myself.
The cost is the best part of this setup to me, I had the plate, the aluminum section and the factory adapter laying around, so I spent very little and these cases can be had for $75-$100 all day around here on CL. The lengthening of the front driveshaft is also an enormous plus for me too because of the suspension travel I'm dealing with. Mine really doesn't need the doubler at all with the engine/tranny I'm using, but the front shaft really need to be as long as it is with doubler to prevent binding. You'll be surprised how easy it is to pull off.
No problem man, let me know if I can help anywhere else. Do you have a build thread on this project anywhere?
I appreciate your taking the time to respond so thoroughly! The main thing I'm concerned about is bringing my truck to Moab next summer, the intermediate shaft breaking, and then I'd be stranded since that was a custom piece.
I mentioned the D&D machine shaft breaking because once it broke, the guy at D&D machine said that was the first one he'd ever seen break. I still think $75 is cheap, but if you're running this behind a 800+ ft-lb duramax that can break the tires loose hauling a load, then I probably wont be able to behind a ~350 ft-lb 5.3L, even in double low.
I'm mostly interested in this setup because of cost and uniqueness (while using mostly easily sourceable parts). 241s are everywhere so if any of those parts were to break I can easily replace them. And the intermediate shaft is so small, I can just toss a spare in my toolbox in case I grenade it.
Anyway, here's my project link on Pirate. http://www.pirate4x4.com/forum/chevy/1093018-2001-silverado-solid-axle-swap-14ff-d60.html
Again, I appreciate you taking the time to respond, and I'm sure I'll have more questions once I get this project started. :rock:
Discussion Starter · #39 ·
"Semi" long-term update:
Just figured I'd report back on the doubler setup. I've managed to accumulate around 25,000 miles on this setup since first installing it in the truck, 7k behind the 6.5/4L80e and then 18k behind the Duramax/Allison. It has now seen a good mix of towing and crawling as well and is doing great as of writing this. I've towed loads up to 19,800lbs total (truck, trailer, contents) verified on a scale without giving it any slack and long distance towing, once from Phoenix to Tulsa with a car on a trailer and a small trailer from Tulsa to Moab and back with no issues. All of this being done with the engine tuned to around the 445hp/800trq at the flywheel level. Surprisingly the homemade stub shaft I welded together has held up as well, so I've stopped being concerned about it. The only issues that it has had was a rear case failure due to an issue I caused and a few leaks that just took some figuring out, so If any one is looking for a way to have highway gears AND low enough gearing for crawling this is about as cheap as it gets!
Really appreciate you updating us. This project has been put on the back-burner for me, but I still plan to replicate what you've done some day. It's great to hear it's held up behind a higher HP and torque setup than I'd be running mine in. Gives me a bigger factor of safety with my welds. :)
21 - 40 of 44 Posts
Status
