MECP Certified
if and when i do put some Xtreme wheels on my 94 sonoma, how far will the speedo be off??
i currently have the base ugly 15x7" steel wheels with some 255/70/15
and am wanting to put on:
Xtreme 16x8" wheels with somewhere in the area of 235/55/16 tires or 235/50/16's
somewhere in that range...any idea if it will be off enough to notice.
Umm... are you sure it is 255??? I think that is a little wide for a 7" wheel? are you sure it isn't 205? Mine is a 205/75/15. If it is a 205, the 235/55/16's will be really close, the 50's will be be about 2 mph off at 60. If they are 255, you will be about 10 mph off with those. I am getting this info from http://www.miata.net/garage/tirecalc.html . That page has a really nice menu and graphic of the tire/wheel and tells a lot of info. I would go there and mess with the tire sizes and see what suits you best.
DogP
Deadbeat
the formula for that is
(New Tire Diameter / Old Tire Diameter) * Speedometer MPH = Actual MPH
to calculate tire diameter the formula is
(Section Width x Aspect Ratio x 2 / 25.4) + Rim Diameter = Tire Diameter
Width in inches = section width / 25.4
Section Height in inches = Width in inches X Aspect Ratio (%)
so yours is (29.1 / 26.2) * 50 = 45
so for every 50 mph your going on the new tires your speedometer will read 5 less ex. your speedo says your going 100, your actually doing 90
MECP Certified
Deadbeat
ok if your speedo said you were going to 100 youd actaully be doing about 97 mph....
i didnt think the calc was that hard considering i used my fingers to calculate that but i've seen calculators on the web...i think s-series.org has one...i think
gumby green
i got to do that soon, i went from a 195/50/15 to a 245/50/16
Deadbeat
wow thats a cool tire calc...definately have to bookmark that one....
